Message |
Yes, I think we are talking about the same thing. Thanks for the direction. Here is a pic of what I believe to be one of the spacers. I think probably should be removed. When flipping the suspension switch, you can barely notice a difference. My memory from 25 years ago was that the difference was much more pronounced. I'm thinking once these are removed it will make a huge difference. https://imgur.com/p5WzwP9 Thanks for the info! :If I remember correctly there were little rubber blocks inserted into the coil springs to keep the car from bouncing around in transit or something to that effect and should have been removed in pre-delivery. Does that sound like what you're seeing? :To post pictures here they need to be hosted somewhere like imgur.com and you can use HTML: : :Or the forum has some short cuts: :[ http://twinturbo.net/nissan/300zx/FAQ/ttnetforumfaq.aspx#html2 ]
